Hi everyone, haven't been on here in a while as been so busy with work and hardly being home. Hope everyone is well.
Ok, I've been having a little trouble of lately with my car. Seems I've got an oil leak which I can't for the love of me find out where, I will have to take it somewhere to get it checked over. Sometimes when I go to start the car, it won't start - it just kind of ticks over. The noise is pretty hard to describe, I'll have to get a video of it when I get a chance but it sort of makes a repeated ticking noise and all the dash lights just flash. Does this maybe once or twice and then it'll start, sometimes the ESP and steering light will be on but go out after a minute.
Plugged it in today and had a scan, log came back with these faults...
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 A HW: 8P0 907 115 A
Component: 2.0l R4/4V TFSI 00 0150
Revision: --H15--- Serial number: AUX7Z0E3FNH00I
Coding: 010300031C070060
Shop #: WSC 00618 210 91869
VCID: 30652062A39E189E2B7-8065
1 Fault Found:
012403 - Fuel Pump Circuit
P3073 - 004 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 201266 km
Time Indication: 0
Date: 2014.09.02
Time: 21:39:29
Freeze Frame:
RPM: 1304 /min
Load: 14.5 %
Speed: 4.0 km/h
Temperature: 91.0∞C
Temperature: 28.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021126
Shop #: WSC 06314 000 00000
VCID: 3A71024A75E2D2CE953-806F
1 Fault Found:
00493 - ESP-Sensor Unit (G419)
014 - Defective - Intermittent
Has anybody had these faults before? Or maybe the ticking noise I described? (Well, kind of)
If anybody has had these faults before, what needs changing and is it a DIY job?
Any help or information would be greatly appreciated, i've checked the codes on RossTech site but wanted to know if anybody here had experienced the same problems.
Sorry for the long winded post, thanks.
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 201266 km
Time Indication: 0
Date: 2014.09.02
Time: 21:39:29
Freeze Frame:
RPM: 1304 /min
Load: 14.5 %
Speed: 4.0 km/h
Temperature: 91.0∞C
Temperature: 28.0∞C
Voltage: 14.097 V
Coding: 0021126
1 Fault Found:
