The DAB radio displaying album artwork as well as the info on the song playing. Very surprised
It's maybe just a "per station" broadcasting option ?
You tried changing the setting in the car set up on screen, you can enable and disable it from thereCan't seem to get the windows down holding the unlock button on the key, it does however open the pan roof up a little?!
New one for me this morning - the MMI helpfully told me my phone battery was low. Helpful that
Yes Ive noticed this too, the only gripe I have with that is that the MMI apparently considers anything below 40% (If I remember correctly) to be low battery. I would personally have set the limit to around 20-25%
If you have the factory-fitted tow bar (as I have) it is expensive but has some very clever features:
- The rear parking sensors are switched off automatically upon connecting the tow ball.
- The ESC system is linked to a trailer stabilisation system which, if it detects that the trailer is swaying, will brake the towing vehicle in order to stabilise the trailer.
- Also you can tell the Traffic Sign recognition system that you want speed signs relevant to towing a trailer to be displayed.
- It is almost impossible to see because it is fitted cleverly behind a panel in the rear bumper.
- The tow ball has a specially fitted compartment in the boot and even comes with a pair of gloves so you don't get your hands dirty!
Found it, thanks! loads of settings - all windows and panroof, front windows & pan roof, pan roof, just front windows etcYou tried changing the setting in the car set up on screen, you can enable and disable it from there
I'm very pleased that your Ford had some of these features but .......
I like your way of thinking and a load more reasons why I love AudiAudi is just nicer to look at, holds its value better and you don't look like a salesman driving it. So all plusses for me
And yes, a bit of a snob
Holding the volume button down on the centre console to switch the entire entertainment system off (including shutting the screen away). Does not come 'on' again until you switch it on (so stays off even when you switch the ignition off and then back on again)
Yes, but it's not just the entertainment system, it's the whole MMI, including bluetooth, satnav etc. There's no way to set the music to not come on when you start the car (though I don't mind this, others do)
