Just had notification of a recall to check coolant pipe on my s3 saloon. Anyone else had this? Apparently it's not urgent, but they sent a reminder one week after the first notification, so I've booked in for the end of the month.
Have you tried to open the coolant recipient (once motor cold !) it should refill itself... Give a try and report back.My coolant level is now on minimum... I've been keeping an eye on it and taking pics (cos I'd forget!) and since end of September it's dropped from 2.5 x x x rows above minimum to this morning being on minimum. It's booked in for a service on Friday, so that's been added to the job sheet.
Let's see what they say...
No letter here, mine is an October build though. Maybe a bad batch of hoses that stretch?
You need G13 Coolant
Diluted 2:3 or 1:1 (Coolant : Water)
(or see label on bottle if extremely winter-y where you are)
Keep it between min and max. My dealer gave me a bottle FOC.
Related Coolant threads:
http://www.audi-sport.net/xf/thread...-on-the-8v-chassis.198794/page-2#post-2287022
Someone woke me up by texting me .....
How do they do the pressure test? I would have thought it was by removing the expansion bottle cap and connecting the equipment there and pressurising.As we speak, mine is kept in overnight for yet another pressure test. If it holds, then it's definitely not the expansion bottle cap. But although Audi have seen several cars that are losing coolant, there is no official fix as they don't know where it's going (no stains).
^ Very good point That thought did cross my mind, although there is very little to go wrong with a cap. Plus, you'd also see evidence of staining around the cap/bottle if the cap was releasing?
My suspicion is head gasket, twice now, I've had a briefest of misfire when I've started it from cold......
