corker1985
I have found this on me rear crash bar any one no what it is looks like I goes to alarm but not sure
As it has a battery pack attached, I would go for an alarm, funny that it's fitted externally! If it was a tracker it would have some sort of GPS aerial attached
It's in a metal box, which means there must be an aerial there somewhere!!You don't need an external gps antenna at all. As the pack is mounted externally and has battery backup, quite covertly installed, it could quite easily be a tracker unit.
Clearly you know better than anyone .....Please..................GPS don't work through metal, you can get a gsm signal using the chassis as an aerial.
