So yeah, that's basically what has happened. Car is not responding well at all. New one on way but has anyone had this problem before? Standard intake hose!
It snapped off on the edge. I bodged it on with a bigger jubilee and it ended up coming off. The car then lost power, ECU didn't know what was going on, smelt funny as well. Luckily I got back home but it doesn't look good. There must be a reason why it blown, maybe the turbo waste gate is seized or the veins perhaps?
They rot and break off... there is no pressure on the inlet side so it won't have blown off... you say it 'snapped' off? if thats the case then this is standard for a rotten OE TIP...
So the car going into slow mode and not knowing what to do is nothing to worry about? I've got a badger5 kit coming, I'm hoping the car is fine again once fitted.
not blown... perished and torn, thats not unheard of.. seen several
Check your engine mounts.. Excess play will be wobbling the motor, and the TIP has to take that wobble as its fixed one end to the airbox.. Keep wobbling anything and it will snap
