Brooksy
- Joined
- Oct 19, 2009
- Messages
- 87
- Reaction score
- 1
- Points
- 8
- Location
- Southampton
- Website
- www.rackmire.co.uk
I've just come across this problem which I can't find anything similar with a search on the forums except maybe a switch or a relay issue.
my headlights won't come on, I get no warning on the dis to say a bulb is out etc, and I get no indication light on the dash either, I've checked the other electrical components from, indications, brake lights, fogs, full beam, sidelights, reverse lights, horn, radio, air con, wipers, washer and blowers and they all work fine. I also get an indication light symbol for sidelights and full beam on the dash but I don't for dipped headlights. I've tried flicking the switch in different combinations ignition off and on again. Went back in after locking the car etc. no sign of life.
anyone had this problem and could steer me in the right direction. Bulbs must be fine otherwise i would get a bulb out warning light, seems weird as both dipped lights do not work. I haven't checked fuses yet as it has happened tonight, but surely other electrical issue might arise too? Or is there a dipped beam only fuse?
Also, so, im using 55w bulbs halogen, I don't have HID's or 100watt bulbs installed.
any help would be greatful
