Rear Control Arm, Collar
PDtuning
Louth Ireland
I bought a new rear control arm from the pass and drivers side but took off the arm and found the don't matchstick the ball joint under the hub.
It looks like a collar is on the arm that came off, do I have to swap this over or should my new are come with it.
02 1.9tdi saloon
You need to swap it over
Mine did the same
Put the collar in a vice and hit the top of the ballpoint and it should drop out
That collar should be in the hub. So as above get it off and put it back into the hub or onto the new arm and fit it.
Reactions: AudiLeon
734
691
22
24
5K
