So after all the mishaps, the car is ready to go and is booked in for Friday. Can't wait to have it all finally sorted.
If it's mechanical then the noise will be there regardless of boost. So if you ran the turbo on actuator pressure only and you still see the same knock voltages(not cf) then the sensors are picking up mechanical noise..
Sensors done up correctly?
Knock windows are worked out in production and set in KFMAKR and KEMLN.
These are independent of actual voltages seen because the actual final cf value and timing pull is based on load/ rate of change of load( KFELDY) and rpm(KFENDY) .. Therefore any mechanical noise say from a clutch will be there regardless of the actual load on the engine,
My point is,, you can have the same knock voltage at x rpm and very different cf values depending on actual load(boost) rate of load change and the rpm it's..
voltage is voltage... cf is factored
