Raymond999
I need bit of advice or if anyone has similar problem how did fix it.
The car is 2007 2.0tdi 170 with 75.000 on the clock.
Now the problem, it's intermittent problem which happens one to two times a week, the car feels like it has no power from 1000rpm up to 2000rpm, it's like your driving with hand brake on or driving in 5th gear at 20mph then when the car hits 2000rpm and it's as if the turbo is on a on switch and then car jerks and then if off like a greyhound.
Now the strange bit it only happens on way home from work which is up hill and 3.5 mile drive.
The car has been into my local indy and no faults could be found.
Yesterday I took the up my local a road in forth gear at 2750rpm for 20 miles to regen the dpf filter as the car has been doing a lot short trips, so thought this might help, I was all so thinking of trying premium diesel.
Any advice or help would be appreciated.
