Fuel pump help needed
goodbuzzman1
I'm replacing my fuel pump but when I took it out this was not connected. How does it clip on to the pump? I can't figure it out and can I just leave it in the tank?
Its a bit off a ball ache that part.
The bit clips in the gap between the pump body and that plate where the wires run down. the gap fits onto the screw you can see behind the wires.
You have to do this process blind as it wont fit into the hole with it attached so do it a couple of times out of the tank first to see how it does it then repeat with both bits inside the tank
make sure no hoses are kinked before reffiting the seal
ahhh makes sense. cheers. i just left it hanging in the tank for ow. will sort it when i get a chance
