willh92
Hi all,
My after run pump is playing up a few months on from when the problem initially arose. Basically, it either doesn't come on or does come on and is spinning really slowly and seems to be struggling. However, if you push the connector towards the front of the engine bay it speeds up and sounds fine. Let go and we're back to square one - usually just cuts out then.
After having replaced the after run pump and its connector the problem still persists, to the point as a temporary fix i drilled two holes in the plastic behind the connector and passed a cable tie through to hold it back in its "working position".
Now it wont work at all, pushing the connector or not so obviously i'm concerned as to any damage to my turbo that may be caused!!
I am at a complete loss with it, i've traced the wires back to the firewall and all seems ok. Is the pump controlled by a relay ? controller unit at all??
Any help / advice will be much appreciated.
Thank you in advance.
Will
Will
