Its cranking slow from cold mate its fine when warmIs it cranking slowly randomly or only when engine is up to temperature?
If it's only when hot then it's a lazy starter. The problem is in the software and doesn't inject diesel until 280rpm, causing the starter motor to work harder. Can be fixed with new starter or a remap to edit the hot starting.
If it is struggling at other times/ when cold then ignore the above!
There seems to be loads saying they are for the a3 yet they are different sizes and powers which did you go for and what price mate? And did the windows sort themselves out?
Southy, go to batterymegastore.co.uk, sort by vehicle and select Varta Silver. Dependent on vehicle it should be about £50, free next day P&P. It's the same as the bosch silver in every way including guarantee.
On the windows, yes they are now fixed. All you do is put them all the way down, continue to hold until you hear a little click/thud. Do the same for putting the windows up. The little noise is the actuator resetting itself.
