New map and i have more smoke but also a lot more power across the range, flywheel is barely taking it and it won't be long before it will throw in the towel ! Turbo is doing 2.6 Bars of boost, should be easily push enough air for my power target...
Base map yes, tweaking was done by a very smart chap in germany ! There was a lot of re-calibrating MAP sensors, boost values and deleting many boost limiters + pulling loads of fuel due to the Bosio Race nozzles pushing so much fuel trough ! Here's a little video i have made, AMD staff doesn't like people on their workshop's floor so had to keep away ! Click on the images for video...Good stuff Chris. Glad you got to the 300 mark. Just out of interest, did you write the map yourself?
Basically same power as a BMW 535 d. Except you have a manual box instead of the slush box. Oh and quattro to make it stick instead of the squirrelly rear end. As you say maybe the only thing missing is bigger brakes, not that they are small now. If you started selling these as a conversion you'd have a queue pretty soon. Well done Chris, i'm delighted, you achieved everything i wanted to and then some. Not bad for a 13 year old barge with pushing 250k miles on it...
Well done and a good result so far - nice to see it on the rollers and all seemed to be good, must be great to drive compared to my standard 180 - wish I lived a bit nearer:thumbsup:
Thank you very much for the kind words Martin, to be honest there's more in the old girl than this, map is very conservative and as i said loads of fuel pulled off from the low and mid range, to be honest it's such a nice drive i prefer driving this more than the s4 ! Thing is the car is heavy, i am running the turbo at a conservative 2.5 Bar of boost- this turbo can do 3 Bar easily ! Building a souped up engine for my old a4 avant and i hope to push over 350 Bhp with a GTB2260 hybrid with a 71mm compressor wheel... I will use a billet aluminium or even titanium wheel for improved spool...
Fair play Chris, you are an absolute nutter! Keep up the good work! I'll pop in and see you when I'm next local to you.
Here you go, looks like i hit bandwidth limit again on photobucket...Do you have a graph of the map (one that you can post up)? interested to see what the torque curve looks like
Most uk dyno's read power at the crank, it's only in the states people use wheel horse power...Hello adamss24,
I would like to know if the dyno graph values are measured at the quattro wheels or are recalculated at the crankshaft of the engine?
Thank you in advance.
Best regards.
Sorry to hear about the car Chris, fairly gutting after you put all the work into a car. At least you are OK which is the main thing, steel can be mended or replaced, bones and skin are a little more difficult .
Do you not thinK that the standard turbine side of a 2260 is a little small for 350bhp and would be a restriction. It's ok putting ever bigger compressor wheels wheels on but getting high manifold pressures will give you high EGT and reduced flow potentially.
Have you ever tried connecting a gauge to measure manifold pressure ?.
Karl.
Not sure mate, you put a lot money into the car which is Queen's property in the end !?! I actually don't feel sorry, a car it's just a car- I am fine and that's what matters ! Might be going for a b5 rs4 soon and still tweak my allroad !Hope your ok Chris ?(thats no consolation though)
Think of it as fate and the possibilities of a bigger and more crazy build .
Gutted
Hi chris been enjoying reading your thread and good to see someone so active on the forum who is knowledgeable and happy to give out advice. I just wondered if there would be any gain to be had fitting a pair of 2.7t inter coolers to a diesel? They LOOK as if they will have a better flow rate and maybe there would be gains from this. They're almost direct fit only the pipe work would need modifying and as I'm a TIG welder that's no problem for me.
The A4 looks nice as it is and should be a real handful once done!
Keep up the good work, glad all your hard work on the engine wasn't destroyed by that idiot driver
Nice thread, looking to up the anti on my 2.5tdi Allroad once the ebay camshaft kit is fitted.
Which kit did you buy, have a link?
Hi, the engine is still in the a6, waiting for the insurance assessor to come round and inspect the car then i will tear the car apart and use the engine in either my old a6 allroad or the 2005 new allroad i just bought last week. Trouble is my old allroad is much, mush tidier and better equiped than the new allroad i have but we all lust for newer cars don't we ?Wow.. taken me days to read this.. what is the engine in now?
