Coincidence or problem?
T tbs Registered User Joined Nov 3, 2012 Messages 44 Reaction score 1 Points 6 Location NULL Feb 21, 2014 #1 Coincidence or problem?
D dualmono21 Well-Known Member VCDS Map User Joined Dec 9, 2006 Messages 1,133 Reaction score 85 Points 48 Location barnsley Feb 21, 2014 #2 drive the car and see if the light goes out often comes on when changing battery ..... if not get a fault code
Mike.M Registered User Joined Oct 11, 2003 Messages 2,512 Reaction score 173 Points 63 Location Dorset Feb 21, 2014 #3 Drive car about 20 meters and the system will set itself
T tbs Registered User Joined Nov 3, 2012 Messages 44 Reaction score 1 Points 6 Location NULL Feb 21, 2014 #4 thanks that has worked
PetrolDave Registered User Joined Nov 25, 2003 Messages 1,559 Reaction score 86 Points 48 Location U.K. Feb 21, 2014 #5 tbs said: Coincidence or problem? Click to expand... Normal, when you disconnect the battery the G85 ESP yaw sensor loses it's calibration. Easily reset exactly as Mike.M described.
