Hi everyone,
Im having some problems that are leaving me baffled!!Audi A4 1.9 TDI
My temp gauge gets up to 90 but if i turn the heating on it drops down a lot.(heating is piping Hot)
If im driving hard with the heating on it doesnt drop as much but still at least 10 degrees.
when i turn heating off and have been driving for an hour and temp gauge is at 90 i can pull up with
the engine running take the reservoir cap off and there is no pressure and water is cold??
I have replaced my temp sensor 3 times and 4 thermostats and have just had timing belt and water pump done?
Also some times when im driving the temp wont go up at all even after half and hour, i can turn ignition off and straight back on and will go right up to 90. sometimes when i turn ignition off the needle drops to the bottom but then flickers a bit,i have also had a couple of occasions when i have turned ignition off and needle drops to 60 degree and sits there with key out ignition?
Any help very appreciated im going mad!!!
