tc light on
sfield
got tc light on and man light on been told its the maf sensor can these be cleaned or are they easy to replace have had a kn panel filter in it mines a 2003 bam engine
I had the tc light come on with a faulty mad, the light only stayed on until the ig notion was switched on and off then rests for a while.
If you are getting a new maf get one from tps.!!! I have 4 cheep eBay ones and a ecp one in the garage....
Lesson learned
Mark
ps i think it was too muck oil on my filter that killed the maf
Try unplugging it and see if the car runs better. Maf I mean.
Mark.
Vcds lite and cheep eBay cable or full vcds is a must.
had it scanned today showed up air mass sensor
Should do, if its a maf fault although I did have to clear existing faults one time though.
As tuffty says would check for faults with a scan
Ok... what was the actual code? makes a difference as there are a few MAF related codes and not all are due to a problem with the MAF..
As already suggested though the TC light staying on is typically due to a knackered MAF but its always a good idea to scan first, post codes and go from there
<tuffty/>
561
758
H
10
742
HansfishS3
H
