Hello Everyone im new here, forgive me if this issue has been previously resolved if you can direct me in the right direction it will be greatly appreciated. Thanks to everyone in Advance for reading my post. I've got a audi a3 2.0tdi bkd engine 2004. I have lost all power steering and the red steering light comes up on dash along with traction control and abs lights. I've checked all fuses seem ok tried having it reset with vcds and it brings up below errors. I think it maybe the power steering assist module on the rack if anyone can confirm this please. I will require Steering rack Part no 1k2423051ac do u still have that rack? After speaking to audi dealers they confirm newer rack upgrade to this is 1k2423055k.
Please help and tell me what you think VCDS data below
Data version: 20121222 Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 7D VIN: WAUZZZ8P44A038072
Mileage: 199860km/124187miles
00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 0
8-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100 46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000 -
--Address 01: Engine Labels: 03G-906-016-BKD.lbl Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705 Revision: 12345678 Serial number: AUX7Z0C6FN3029
Coding: 0000072 Shop #: WSC 06435 000 00000 VCID: 27568CF2965C0820406 No fault code found. Readiness: 0 0 1 1 1 -------------------------------------------------------------------------------
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 D Component: ESP FRONT MK60 0102 Coding: 0055942 Shop #: WSC 06435 000 00000 VCID: 336E68A252847480ECE 1 Fault Found: 00810 - Sensor 1/2 for Brake Pressure 005 - No or Incorrect Basic Setting /Adaptation -------------------------------------------------------------------------------
Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 D HW: 8P0 820 043 D Component: KlimavollautomatH12 0150 Revision: 024730 Serial number: 8P0820043D Shop #: WSC 00000 000 00000 VCID: 2D5A7EDAB4A02270BAA No fault code found. -------------------------------------------------------------------------------
Address 09: Cent. Elect. Labels: 8P0-907-279-23-B.lbl Part No SW: 8P0 907 279 HW: 8P0 907 279 * Component: Bordnetz-SG 1.0 H27 0401 Revision: 00000000 Serial number: 00000000084648 Coding: 00884F00A2141000000000000000000000 Shop #: WSC 00000 000 00000 VCID: FAF00586B56EC5C8EF8 Subsystem 1 - Part No: 8P2 955 119 A Labels: 1TX-955-119.CLB Component: Wischer WWS Audi350 0170 Coding: 16711696 Shop #: WSC 00000 No fault code found. -------------------------------------------------------------------------------
Address 15: Airbags Labels: 8P0-959-655-84.lbl Part No SW: 8P0 959 655 F HW: 8P0 959 655 F Component: Airbag 8.4ED H01 0130 Coding: 0011602 Shop #: WSC 06435 000 00000 VCID: 458A267A0C10FA3052A 1 Fault Found: 01738 - Crash Sensor for Front Airbag; Drivers Side (G283) 011 - Open Circuit - MIL ON -------------------------------------------------------------------------------
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 A HW: 1K0 953 549 A Component: Lenksäulenmodul 008 0030 Coding: 0000012 Shop #: WSC 06435 000 00000 VCID: 306467AEA3924F9891C No fault code found. -------------------------------------------------------------------------------
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 980 D HW: 8P0 920 980 D Component: KOMBIINSTR. VDO H25 0070 Revision: D04 Serial number: 2246CD04001083 Coding: 0004403 Shop #: WSC 14557 067 57207 VCID: 38745F8E4BE297D8D9C No fault code found. -------------------------------------------------------------------------------
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 B HW: 1K0 907 951 Component: Gateway H08 0070 Revision: 08 Serial number: 20001036257263 Coding: 3D0F0B4A070101 Shop #: WSC 06435 000 00000 VCID: 264881F6915611287B0
3 Faults Found: 01309 - Power Steering Control Module (J500) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 101 Mileage: 199864 km Time Indication: 0 Date: 2013.01.24 Time: 00:49:36 00470 -
Combination comfort Databus in Single Wire 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 101 Mileage: 199864 km Time Indication: 0 Date: 2013.01.24 Time: 00:49:36 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 101 Mileage: 199864 km Time Indication: 0 Date: 2013.01.24 Time: 00:49:41 -------------------------------------------------------------------------------
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 980 D HW: 8P0 920 980 D Component: KOMBIINSTR. VDO H25 0070 Revision: D04 Serial number: AUX7Z0C6FN3029 Shop #: WSC 14557 067 57207 VCID: 38745F8E4BE297D8D9C
