hi anyone had probs with auxillery water pump on s3 bam engine, mines stopped working, checked voltage at plug, 0.6 volts, it pulses to about 6 volts every 10 seconds, its got me beat.
had same problem tuffy gave same advice . again my fuse was fine , however the connector to the fuse had burnt out ! the fuse was fine the connector was toast it has giv in before the fuse check it properly bud coz after a week mine boiled over n split a few brital plastic water hose connetors and when sourcing new it was a weeks back order on the parts . worth a go coz it sounds like same issue made , its not offten tufftys wrong bud
