I'm not saying a word.................
Take it back to dealer asap ,also could you zoom out a bit?
Take it straight to the dealer get then to check it out ,looks like somethings missing and damaged ..?
Paint is flaking off quite badly but I get accused on here of moaning too much! It's coming off clean suggesting it isn't bonded to the plastic particularly well.
Best get it ,straight in to dealer under warrenty ..;)
i dont mind at all you asking any questions ,thats what the forum is for :icon_thumright: Also you bought new ,i take it right back and get anything fixed asap....
I noticed as I washed mine before it went away it was doing the same thing in the exact same place, more came off whilst jet washing!
Itll be going in to be sorted once I get it back
Would you trust 'Audi' workshops or insist someone of your own choice?
Guys mine has been in for this, one paint shop (Audi approved and associated with 3 dealers) says it's covered and another and the people at Audi Uk say it isn't...:wtf:
Yes it's the rear wheels arch side on the bumper, the paint flakes off far too easy.....:keule:
Mine's exactly the same Gareth, it's just gravel rash; at least it wont rust!
[/IMG]
Most of this being the consequence of a fabulous Sunday in Wales... Pure joy!!!
Do they do the whole bumper or just the 'ends'? Why did Audi UK say it isn't covered the car isn't even two months old with 1800 miles on the clock and probably only it's third wash since I bought it?
Glad I'm not alone then but pretty poor for a £40k car - sorry sounds like I'm moaning again but that is hard earned cash and I didn't just buy an engine I bought the whole car.
Halfords and a brush… It's virtually impossible to get any paint to withstand road debris being hurled at it at such speed and in such close proximity to a rear tyre (metal or plastic bodied cars): even a rubberised paint will show signs of wear - it's just the same as grit/sand/bead blasting, really. So Halfords and a brush or leave it alone… Go for a drive and forget it! :racer: If you repair it, then it'll be back again by the autumn.
And no, you're not! :blink:
Reactions: 8PARSY
Dont think its normal John, Its come off in flakes not stone chip sized pieces.
It'll be going in for them to assess as soon as it comes back, Ive only got 3500 on the clock so wouldnt expect it to be that bad even with my driving style...... Lets be honest 90% of its job is a daily commute in slow traffic during the week.
Reactions: 8PARSY and PigPen
I sincerely hope I'm wrong, but years of painting cars; steel, GRP, and current thermoplastics, the adhesion to a plastic surface, even using aggressive etch primers, is not 100%, and on 'plastic' panels especially, it will result in this sort of 'damage'.
And here's one I did earlier, much earlier…
Reactions: Macdaddy
Hi Pigpen......
Mine's the same, looks worse in lighter colours...... White, Suzuka etc.
tbh I'm not really bothered, it's clearly a plastic part and the paint's failing at that point. Wouldn't worry about it to much:icon_thumright:
Reactions: 45bvtc
I can't be driving mine as quick as you boys cos mine hasn't flaked off yet,
Reactions: 8PARSY, wickedstef, Mr_Freeze and 2 others
Mine's black. If there's a problem, I can't see it.
However, the windscreen has just spontaneously cracked on the bottom left!
Cracked windscreen may well be thre tiniest of stones that has hit it. It is one of the highest stress points in the pane where you have described as I have had similar with no visible mark to say it was a stone.
Reactions: monkeyboy_marcus
Mud flaps?
The fact that looks black seems like the primer layer has not adhered to the bumper.
I would have said if they were chips and it had been painted properly there would have been parts where only the top coat had come off only.
Been to look on my missano red (multi layer paint effect with white under red) a6 and the plastic bumper on there after 6 years and 78,000 miles does not look like that and surly audi would still use similar techniques to paint their bumpers.
Give them hell......
Reactions: PigPen
I'll have another close look during daylight to see if I can ID a chip. Otherwise, a warranty claim maybe? Why not, Audi can replace it the same time as they do the brake squeal fix, which is any day now...
Anywho, back to paint. I'll have a closer look at mine to see if there is paint peeling in the specified locations. Not too bothered if it is just over black plastic and not metal.
Reactions: 45bvtc
My mum once had a brand new civic and the windscreen went in the first week of ownership.
Second windscreen was fitted at dealers and broke on fitting.
Turned out there was a small weld blob on the frame and the pressure was cracking the screen.
Agreed, had them fitted since day 1, despite being ridiculed for them on another Audi forum, they work well and protect the paintwork from just this sort of damage.
regards
Are they standard Audi flaps? Do you have a link?
Inspected mine more closely today and there is no sign of etch primer on the return lip of the rear bumper, only paint, which is why the paint is coming off in flakes (paint does stick to paint).
Within the stone chips (see post #13) on the outer/visible lip of the wheel arch, however, the 'grey-coloured' etch-primer can clearly be seen.
If I care to rectify mine, it'll be with some 600 grade wet and dry (to give the paint something to bond to) and brush paint it in - otherwise I'll leave it alone.
Reactions: 8PARSY
I am more worried where the primer starts as one of mine already seems to have disappeared underneath.............seems a bit poor to prime (hopefully) part of the part but stop short on the ends.
Could it be an Audi/VW primer cost reduction exercise hoping the customer will not notice? It can't be operator error as others are reporting the same, so most likely a production/procedural oversight/error. I can well understand how it’s happened in the production process. Still not right mind, but as with the brake issue, what chance?
Reactions: 8PARSY
Had a phone call.........................
Go on!
I've just been down and pointed out the issue to the dealer, They agreed it should not be flaking like that so are going to sort it along with the stone chips they've added.
Reactions: PigPen and 45bvtc
So what was the outcome here??
Just a clean and polish and a bill for £28. Sorry should have reported earlier :notme:
