Boot release button disable on door
  • Thread starter Deleted member 21388
  • Start date
D
Guest
I've some how managed to disable the boot release via the button on door of my MK2 TT, probably by my messing with vag com
It still works on the remote key fine, as does the fuel release button next to the boot release on the door.
Any idea where to undo this in vag com
Thanks in advance
Richard
Did you have a log of the car before you changed anything?
Lol that would have been far too sensible of me !
After 6 years of messing with vag com just found out that the log files can be used as a backup.
I'm going to take the door panel off when I have time to see if I have not connected something back when I put the puddle lights in, but I doubt this as the fuel release works and the switch lights up as normal. - Hence why I think its something I've done in vag com
Richard
Richard, post up a full scan of the as it is currently coded, I will compare it to SWMBO’s MY11 TT.
Gizmo do you post on TTforum as well ?
This is an auto scan I did last night - fingers crossed I did this right
Chassis Type: 8P0
Scan: 01 03 08 09 10 15 16 17 19 22 25 26 42 44 46 47 52 55 56 61
77
VIN: XXXZZZ8JXXXXXXXXX
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 DT HW: 03L 906 018 DT
Component: R4 2,0L EDC H23 7766
Revision: 42H23--- Serial number: AUX7Z0K2FNH00I
Coding: 00190012042700080000
Shop #: WSC 01236 785 00200
ASAM Dataset: EV_ECM20TDI01103L906018DT 003004
ROD: EV_ECM20TDI01103L906018DT.rod
VCID: 7F23CAFDE6E4F3E0586
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 B HW: 8J0 614 517 B
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0083827
VCID: 2C79CDB18F12B878AD4
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 BB HW: 8J0 820 043 BB
Component: J255 Klima 1 Zone 0110
Revision: 00H09006 Serial number: 00000001181735
Coding: 1049876
VCID: 67F3729D56745B20806
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 H HW: 8P0 907 063 H
Component: BCM PQ35 H 108 0615
Revision: 00108 AG
Coding: 4600012FE205F1202070E8E00180894C577E58AA3120D128DC000E440045
Shop #: WSC 01236 758 00200
VCID: 3957E4E5B0401DD0262
Subsystem 1 - Part No SW: 8J2 955 119 A HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00FD10
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02492C
Subsystem 3 - Part No: 8J0 951 177
Component: DWA-Sensor H0 H03 0030
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36891108157146
Coding: 00000B
VCID: 48B19121FBAA7458A9C
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -t Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K00551JG
Coding: 0011636
VCID: F9D7A4E5B0C05DD0E62
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0003041
VCID: 46AD9F1931BE62285B0
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 8P0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H43 0311
Revision: H43 Serial number: 280311F1003066
Coding: 355101
VCID: 334BD6CD922CE780ECE
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 44A9851107825038454
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 8J0 920 980 R HW: 8J0 920 980 R
Component: KOMBIINSTR. VDO H01 0591
Revision: D0H01004 Serial number: AUX7Z0K2FNH00I
VCID: 40A18901139A4C1861C
Address 26: Auto Roof Labels: 8J7-959-255.lbl
Part No: 8J7 959 255 D
Component: 256 VSG TT H18 0150
Address 42: Door Elect, Driver Labels: None
Part No SW: 8J7 959 801 N HW: 8J7 959 801 N
Component: Tuer-SG H04 0101
Coding: 0000630
VCID: 47B3921D36B47B20A06
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 8J0 909 144 M
Component: EPS_ZFLS Kl. 236 3201
Revision: 00H20000
VCID: 3A55FBE9754616C82F8
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000025470
Coding: 0136133
VCID: 256F3895ECF8893072A
Address 52: Door Elect, Pass. Labels: None
Part No SW: 8J7 959 802 N HW: 8J7 959 802 N
Coding: 0000628
VCID: 48B191213BAA7458A9C
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000010
VCID: 3C59FDF17F7228F83D4
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8J0 035 195 G HW: 8J0 035 195 G
Component: R Symphony2+ H08 0281
Revision: 00H08000 Serial number: AUZ1Z4L0545527
Coding: 0730301
VCID: 3041D9C1A33ADC9891C
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 0311
Coding: F302015A
VCID: F4C995D157A220B8B54
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005360296
Coding: 0001202
VCID: F4C995D197A220B8B54
End ---------------------------------------------------------------------
Richard
Login to module 09 & there will be a long coding option to resolve this as afaik, you have the newer 063 ce module in 09, so all conv module functions are in 09 now, not 46.
Yes I am also on the TT forum.
As the car was purchased:
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8J8 959 801 H HW: 8J8 959 801 H
Coding: 0004661
VCID: 4280FFFF1D94F03
This was later changed to:
Coding: 0004725 when the puddle and door opening warning lights were added.
I have also coded another 60 plate TDi TT which was:
Coding: 0004733
VCID: 4280FFFF1D94F09
Note these both use a slightly different part number for the door controller.
I will check the car tomorrow to see what each coding does on thhe car.
Thank you - I will have another look at the car tonight and see if anything looks obviously wrong.
I do have the orig setting for each door - as I took a picture of the setting before I changed them - lazy I know !
0-8j7 959 802N Tuer SG H04 0101
Software coding for drivers was 0000565 -
passenger was 0000564 -
I added 64 to each of these value to get the puddle lights to work.
I will try re in putting the orig setting to see if the boot release works.
Richard
