Can this be done by myself or do I need certain equipment to check values etc --IF it can be done by myself can someone provide a guide or link to one?
Thank's
Honestly mate, it is such an easy fix.
Quick guide:-
1.Remove fuse side panel.
2.Remove 1 x 8mm bolt
3.Remove 2 x 8mm bolt under panel.
4.Remove connector from clutch swith
5.Turn clutch switch anti clockwise and remove (remember the way it came out)
6."Before you install new clutch switch, pull plunger all the way out, press clutch pedal down, re fit the new clutch switch, slowly depress clutch pedal so the plunger finds its own level.
7.Reconnect the connector.
8.Put the panel back on.
Job done
If you honestly don't feel comfortable doing it, then as already asked, where are you as I am sure there is someone local on here who can help you out.
Seriously mate, not much any of us can do. Plus thought you would have fixed this by now as I am sure you started a different thread back in August???
