Of course this information is correct, my reply was based on wheels with ET35 offset, basically, the range is ET25-35 on the fronts and ET 20-35 rear, you could probably run 20mm's on the rears, I'm pretty sure that will clear.
I run ET5 rear on 8.5s, if it wasn't for that stupid little plastic "block" on the outside arch liner, it'd be fine. Rubs ever so slightly now and then...
