Well just went back to the local Audi parts and ordered up the black grille surround (8P4 807 715 VMZ - frame black).
Decided I'd give it a try and if I don't like it I'll just sell it on.
They only had a couple of small parts in off my list (wheel nut caps and the yokey's to hold up the parcel shelf) but the others should be in monday.
Did a scan on the car this morning and got these DTC's...
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC G000AG 7000
Revision: 12345678 Serial number: AUX7Z0E4FND08E
Coding: 0000078
Shop #: WSC 06314 000 00000
VCID: 78FBECD37013
2 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 000 - -
Freeze Frame:
RPM: 840 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00101100
Temperature: 14.4°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 000 - -
Freeze Frame:
RPM: 840 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00101100
Temperature: 14.4°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Cleared and hasn't come back yet
This one too...
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000186D088505489FC63000
Shop #: WSC 00481 210 88137
VCID: 3C7330C304AB
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground - Intermittent
No idea, need to search it up
This...
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3E3197724
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 326F1EFBD6EF
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
This could be there from the previous owner who had an aftermarket unit in apparently, back to the original now.
These...
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG 010 0030
Coding: 0000216
VCID: 3E773ACB12B7
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 B
Coding: 0000216
VCID: 3F8947CF15BD
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
Just need to reset the motors, handy enough I've heard.
And lastly.....
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 HW: 8P0 919 283
Component: Parkhilfe 4-Kan H06 0030
Coding: 0001013
VCID: F8FB6CD3F013
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 11
Reset counter: 198
Mileage: 119246 km
Time Indication: 0
Date: 2011.09.11
Time: 13:05:55
Again need to look it up.
So more stuff to fix up, everyday it gets closer to a can of petrol and a match
