Otherwise you'll have 2 x 50w+ going to the fronts and still have the feeble 2 x 20w going to the rears from the Audi rear amp. You can pick up the feeds for the rears from the connector on the Audi sub, so no need to dismantle half the car.
Andy do you have a link for an amplifier adaptor that could be used with quad lock (07)? Is it possible to get one which incorporates steering wheel controls? I've had a look at auto leads and connect 2 but not sure which one i need.
Planning on changing my rns for an alpine one unit in the next week or so
non-bose btw
in your case as you are just using a new HU and not playing with anything else i would guess that you are using the wrong harness adapter as it should have just worked.
Theres one thing I dont get, why is there RCA's on it? I will be fitting an Alpine headunit.Yes the one I posted above PC9-404
