Get a diagnostic, this should give you pointers, could be low pressure in the fluid used in the AC, to the fuse in the engine bay blown, the air con fans are linked to a fuse that powers the manifold flap motor which goes quite common...
plugging it in should give you answers, even look for someone on the VCDS map on here!
