I bought an MK4 dual gauge column pod (i need one for afr and one for boost) and it didnt fit bolt on, but ill make it fit. It will need a bit of trimming and i assume it will go in place.
Hmm, yeah been told it takes a bit of modding. If your doing it soon id be interested in seeing pics. I seen a pals single gauge on his octavia and to be fair i wasnt overly impressed. I dont want it literally blocking the DIS or a good chunk of the dials. Maybe ill just have to resort to a nice neat A pillar install.
Anyways, as mentioned i got the intercooler off to my pal for final modding. When i took it last time i only took a few measurements and a brief description. As Bens a skilled lad he made it quite well, however on fittting, the bumper did foul slightly and one of the pipes wasnt quite right. So i took lots of measurements, made a few sketches, photos etc and made sure he had all the info required to finish the job this time. You live and learn eh...?
Whilst on my travels i popped in to see Andy Outhwaite, who decoded my ECU for me. Always nice to see Andy, top lad and top service. So now ive got a nicely decoded ECU...
Which as i had a few hours spare today, i fitted...
And then i cracked on with fitting the the remaining heatshield to the top of the engine bay. Cut my hands to absolute bits with this last fiddly bit!! I used the existing fixing points on the bay from the old heatshield and also the metal coolant/breather pipe that normally sits at the rear of the bay. im ditching this pipe as one of the pipes is the coolant, which i can easily re route, and the other is the charcoal cannister breather pipe which is also going the distance, so the pipe is redundant, and to be fair in the way!! lol
So with that now fitted i could get the turbo re fitted...
And then i could re-check the tolerance on the turbo to bulkhead distance..
Theres basically 10-15mm between the top of the turbo and the bulkhead, and theres even more at the rear. To test i put the car in gear and rocked the car to get the mounts really working. I dont think the turbo comes near at all so im happy that its all ok. If i do get problems ill see about a poly insert for the dogbone.
I could also crack on with gettin the coolant pipes all fitted...
Which im happy with. Did a load of little jobs like connecting the main earth strap to the engine, aswell as the main +ve terminal to the starter motor. And then i thought id get the battery box on, so that i could get the Neuspeed Pflow induction kit fitted and have a look for issues...
I bought the p flow kit ages ago and now that its out of the box im thinking about whether its up to the job of supplying the air i need. Thoughts on this please as its a nice piece of kit, but ideas on whether its big enough for my requirements would be good...
I cracked on fitting little bits and bobs though...
And then the job of replacing the sump for the oil sender type. Sump off...
This is what your oil pickup should look like...
One final scrub up of the sump my pal donated...
And then i fitted a magnetic sump plug. Good little bit of kit this, esp as itll be running in so therell probably be lots to catch...lol
And fitted...
And then just a simple case of silicone, and faff on witht he bolts, all to 15NM as per elsawin...
And now i have the sensor cable all dressed in and connected.
The only other little task i set about today was the PCV system. Im keeping the 90deg bend out the of crankcase breather, however this connected to some gash pipes etc, so i simplified this with one little bit of pipe to join tot he metal pipe...
Which is good to have. On my AUQ lump i had in the mk2, this metal pipe didnt exist, s i had to connect the crancase breather to the rocker cover breather and T off to the catch can. I wanted to do this a bit different so to achieve te same i needed to add a takeoff to this pipe...
Which i cut off an old coolant pipe i had lying around...S3_kev
First i decided where i wanted this takeoff, and then pin punched it...
Broke out the cone cutters...
And cut the hole...
Then switched to a sharp countersinking bit...
to ream the hole out...
Photo taken mid way through the reaming. I then offered the takeoff up...
And had to file that little bit showing on the right of the inside of the pipe. Then with a little bit of work with the files, got the two to mate nicely...
And then spot welded it (crap pic i know...!!)
And then lots of nicely penetrating spot welds all around...
Dressed them back with a file...
And when i was happy i prepped and painted the pipe...
So with it all finished and new takeoff added...
Ready to fit onto the engine...
