hi people im new on here, ive recently got a 2001 plate s3 i have got a few problems that i wondered if someone may be able to shed some light on for me ....
basically when i put my foot down it boosts up fineto about 16 psi ish, through say 2nd and 3rd gear then sometimes hesitates and the boost drops to around 10 psi???
i have noticed the car had an aftermarket airfilter and a non genuine looking recircualtion valve on it ?? ive put standard filter back on but could this aftermarket and possibly cheap recirc valve be causing this????
if so would a forge 007p cure my fault...
also one more fault the oil level sensor light was on when i got it in yellow ... the bloke said i needed to change the sensor, ive done this and light is still on , ive disconnected battery and re connected it says ok intially then after about 3 mins comes up again... ive checked the wires to it best i can and they seem ok . does anyone know of faults like this ???
thanks guys
thanks guys
