PANEL&TRIM REMOVEL ON A3
allhell
HI I WONDER IF ANY OF YOU HAVE EVER REMOVED THE TRIMS AND BUMPERS ON YOUR A3'S FOR A RESPRAY.MY PROBLEM HAS COME ABOUT AFTER A DODGEY SPRAY JOB BY THE GARAGE I BOUGHT THE CAR FROM,THE PARTS ON THE CAR I WANT TO REMOVE ARE THE SMALL PLASTIC TRIM BELOW THE SIDE PANEL OF THE CAR(THIS APPEARS TO BE ATTACHED TO THE PLASTIC INNER WHEEL ARCH). ALSO IS THE SIDE WINDOW RUBBERS GLUED ON OR CAN THEY BE REMOVED,I WAS TOLD THAT THEY WE'RE GLUED IN AND REMOVEL WOULD CAUSE ALL SORTS OF PROLEMS WITH WATER GETTING IN .TO PUT YOU IN THE PICTURE OF HOW BAD IT IS IMAGINE A LOVELY SILVER CAR UP TO THE REAR OF THE DOOR AND THEN THIS TOTALLY DIFFERENT COLOUR SILVER FROM THERE ONWARDS WITH SILVER OVERSRAY ON THE PLASTIC TRIMS
[1] Welcome to the forum
[2] Someone has to tell you so it may as well be me. CAPs on in web etiquette is SHOUTING.
[3] Try dropping this in the A3 and you'll more likely get an answer.
/ubbthreads/images/graemlins/wink.gif
