EM TuningVolks Autos
Results 1 to 10 of 10
Thread: AEB oil pump
    Feb 2007
    AEB oil pump
    Changing oil pump on a 98 1.8T A6. Engine code AEB. What a ***** of a job getting the sump off. Does the subframe have to droped to remove the sump and the oil pump? Can anybody help.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    Hello and welcome and post in the A3 section regarding pump might get some better replies
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,883
    Hello and welcome.
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    Feb 2007
    Ok. Hi anybody thinking about changing a oil pump on a AEB 1.8T, in an 98 A6.
    Just finish the job. Hope this helps. You do have to drop the sub frame. Tried undoing the engine mounts and lifting the engine up, but is just doesnt give you the room needed to slide the sump out and will not give you the room to extract the oil pump. Plus it is so much easier, with the sub frame hanging, to get at all the bolts holding the sump on. This, once the sump is removed will also give you the room to pull out the oil pump and its shaft.
    Now the reason Im changing the pump. Had the oil warning light come on, while slowing down from motorway speeds, when hot. Fine at 70+ and at tick over, but not at 1200 to 2000rpm. Oil warning light came on. Thought it was the typical oil strainer choked up, but no. It was the pressure relieve valve. It was heavily scored and sticking. After the oil light had gone out the engine sounded very tappetty! If you stopped the engine and started it after 30 seconds, the engine was quiet again. Maybe the relieve valve had freed its self with no pressure in the system? Hope this helps and may give some indication to oil pump problems!
    L1 HCS's Avatar
    Candy Tetris Champion, Mahjong Champion, Magic Ball Champion
    Oct 2006
    cymru
    4,597
    Hello & to the site.
    "Swallow your pride occasionally, it's not fattening." - Frank Tyger
    "Avoid making irrevocable decisions while tired or hungry." - Robert Heinlein
    SamDude's Avatar
    Jan 2007
    London
    2,091
    Howdy!
    Welcome'n'all that!
    Randles's Avatar
    Feb 2007
    South Wales
    96
    Hi and
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    n all that..!!
    2004 1.9TDi A4 Avant Sport, GmbH bodykit, DPM Remap, Fishscale Alu trim, RNS-E
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Quote Originally Posted by les riva
    Welcome, and thanks for the tips, its things like that,that make this the fantastic resource it is
    Randles's Avatar
    Feb 2007
    South Wales
    96
    Enjoy your stay
