Badger5JMB Retrofits
Results 1 to 7 of 7
    Oct 2006
    Can I upgrade oem amp
    Hi
    I feel its my amp thats giving problem when I am playingback on high volume. this is because the volume suddenly drops completely to 0 volume. It then starts to pickup after 60 seconds or more at times. Can I upgrade the factory fitted amp in the A4 Avant 2003?
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    its probably your head unit volume switch thats the problem !
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Hello.
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I wouldn't advise upgrading the amp, maybe try substituting the head unit as Olly suggested, if you want to fit a new amp, fit a new head unit as well, or you'll end up in a whole world of trouble unless you are an experienced auto electrician...
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    smitch's Avatar
    Sep 2006
    1,585
    Isn't this the welcome section???
    S4.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Hello and welcome
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    S3g
    Dec 2006
    Quote Originally Posted by Olly_K
    Very common in Audis try getting some switch cleaner in there or get it repaired..
