EM TuningBadger5
    Dec 2013
    audi a6 quattro avant 2.5tdi fuel problem?????
    Hi All, I have an audi a6 b5 2.5tdi quattro avant 2001 reg, problem im having is when i have below half a tank of diesel in the tank my engine sometimes refuses to start and has to be cranked over quite a few attempts before starting and engine will sometimes cut out when driving at low revs? seems to run great and start no problem when there's over half a tank reading on the fuel gauge? ive not long had the car and bought it with an oil sensor light on the display i initially thought it was the oil temperature sensor as the oil temp gauge was not reading 90c as as engine temperature reads when running at normal temp.. anyway i replaced the oil temp sensor and it still doesn't work but that's another issue???? so could the oil sensor alert light on the dash which is permanently on be a sensor in the saddle tank? ive read on the forums that the quattro tank has a sensor on either side of the tank to make the intank pump keep level on both sides of the tank? could it be that one of the sensors is faulty? or a relay at fault? and is there a fuse or a relay for the oil tempreture sensor????? any help would be great.....
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Hi welcome to audi-sport.net. Where are you located? Any pics? Enjoy the forum. x
  1. Audi A4 Quattro Avant
    By damo31 in forum For Sale/Wanted - Audi Cars
    Last Post: 28th September 2013, 06:27
  2. audi s4 quattro avant 1999 breaking
    By egesford in forum For Sale/Wanted - Audi Parts
    Last Post: 26th January 2012, 19:41
  3. audi s4 quattro avant 1999
    By egesford in forum For Sale/Wanted - Audi Cars
    Last Post: 26th January 2012, 18:07
  4. Audi A6 "C5" avant 2,5tdi tip quattro xenon lights leveling
    By A3SBQ in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th January 2011, 13:57
  5. AUDI RS6 QUATTRO AVANT 2009
    By Jason 70 in forum RS6 Forum
    Last Post: 26th February 2010, 13:48
