JMB RetrofitsBadger5
    Mar 2012
    Angry Mass airflow sensor/ Intake manifold flap
    Hi, new to this so bear with me !!!! Got an audi A3 2.0 tdi, A light came on about a month ago, looked in the manual and said emission control system fault, been told its an engine management light since. Had someone come out out and plug his laptop thingy into the car and the fault that appeared was the intake manifold flap was not opening/shutting correctly. New intake manifold flap part bought from cardiff audi (£360) and fitted, thought the light would go out but still on !!!! noticed the fuse (F7) had blown, put a new fuse in and was hoping the light would go out !!!! But nope still on !!! Had the same guy come out again, plugged in the laptop for the faults and it is coming up 16486 mass flow sensor-g70 signal too low P0102 !!! Light has been on permanently for about a month now, Is it worth me taking this sensor out and cleaning it myself with a rubbing alchohol ? Will this clear the light ? Any info would be much appreciated !!!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Hi, welcome to ASN. Whete are you located? What year is your car? Any pics? Have a look over in th a3 section. When I know what year your car is I will be able to help you more. Enjoy the forum.
    Mar 2012
    Hi, I am located in Cardiff, south Wales, have a 2.0 tdi a3 sline, 54 plate.Thanks Sandra, just trying to work out how to use this forum, will try & post a pic.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Mark, have a look over the A3 8p section, its just a few places down from the welcome section. Lots of info and helpful people.
    Link for psting pics below.
    How To: Post pictures on the forum.
  1. Problem with: motor for intake manifold flap malfunction 19559 v157
    By kaos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2011, 14:59
  2. Help - Part Number for Motor Intake Manifold Flap - EGR Valve
    By miszka20 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd July 2011, 20:02
  3. Intake manifold flap
    By 347 in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd November 2009, 23:12
  4. *fault* Motor for Intake Manifold Flap
    By a3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2007, 12:54
  5. Mass Airflow Sensor
    By Passatman in forum VCDS (formerly VAG-COM) forum
    Last Post: 7th November 2006, 17:39
