Sky InsuranceJMB Retrofits
Results 1 to 7 of 7
Thread: Troublesome A3
    Sep 2009
    Troublesome A3
    Firstly, hello to all. I'm new to this so here goes... The story so far, 2005 A3 2.0 TDI 140 sport, sportback with all the toys, lovely car but started to have a problem with power. Car goes into limp mode when under load and can be reset by turning off/on, not entirely safe at 70mph but it works. I have checked the vacuum pipes and was able to operate the vane adjustment rod on the turbo full range by sucking (until my eyeballs popped). I have ran with the MAF disconnected but this is worse (no boost at all). I have also cleaned the sensor in the intercooler pipe and checked for other stuff, loose,split pipes, wires etc. Then second problem after checking and grubbing around all day yesterday I found today that the front washers and the rear wiper do not work. The fuses are ok. Pleeeeeeeeeeeease help.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    you need to hook it up to vcda for codes
    if no codes you need to do a few logs
    could be any number of things
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Welcome mate
    Sep 2009
    Boost pressure regulator limit exceeded over boost intermittent. P0234.
    cylinder 1 glow plug circuit electrical fault P0671, cylinder 3 p0673 and cylinder 4 P0674.
    ta.
    Sep 2009
    Moochessgrassyarse.
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    Hi & welcome to ASN! post this over in the a3 section and you will no doubt have more luck gettin answers!!
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    Sep 2009
    Cheers fella.
