AMD TechnikKowalski
    Robbyc's Avatar
    Jul 2004
    Solihull, W\'Mid, UK
    Post Thanks / Like
    2000 golf gti HELP!!!!
    Hi all hope someone can help on this problem I have. I've not long brought this car and have had an error come up on the vag com, fault code P0170 fuel bank 1 maulfunction. I've changed the MAF and had the rest of the car checked pipes oxygen sensor, coil packs etc, and no joy. I also have had to change the oil pick up as it keeps generating this hard black s*** in the oil could be carbon but not sure, I think maybe these two problems are connected. Has anyone had this problem or know of someone that has.
    Regards
    Robbyc
    Jul 2007
    95
    Post Thanks / Like
    How have you checked the lambda? It sounded to me straight away to be the lambda, then I found this:
    http://forums.clublupo.co.uk/index.p...3&#entry426253
