Adrian S FluxForge Motorsport
    Hairy Ballbag's Avatar
    Mar 2007
    West Sussex
    60
    Post Thanks / Like
    VW Golf - Duff Braking!
    The Mrs has a '97 MK3 Cabriolet 1.8 8v and getting into it from the comfort of my 2.8 A4 Quattro, was decidedly worried my dearest was driving around in a car that you have to bury the brake pedal into the floor mat to halt the thing.
    The front discs are EBC, pads are EBC green stuff and the rear drums are about 2000 miles old. It has ABS, yes even with drums on the back - so as the actual stoppers are in order, I'm wondering where the problem lies.
    Fluid is full so I'm wondering if the master cylinders are just cack in these things.
    Does anyone know if you can substitute one with a better compression ratio as a straight swap out of another car? I.e would a GTI one be better and would it go straight in?
    Ta - Jon
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Post Thanks / Like
    I'd get the brake lines bled first, sounds like you have air in the lines which allows excess brake pedal travel
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
