UnicornSky Insurance
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    golf poor power!
    115 BHP PD GOLF TDI 2001.
    It will go upto 80mph,then start to drop speed,if i try to go over 80,it will do it but it will take a while.
    If i drive it and im in say...3rd gear and i slow down and put it in 2nd gear, if i put my foot down it wont go,slow as a slug!
    Also get a vibration underneath the front of the car.
    new maff fitted and no fault codes via vag-com
    A4Quattro's Avatar
    My BM is fixed!
    May 2004
    Kent
    4,851
    Post Thanks / Like
    Any hoses off? Changed the fuel filter recently? Does it rev up out of gear?
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    vw754's Avatar
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    no pipes off,new filters,revs full when on idle.
    Teutonic_Tamer's Avatar
    GreasedMonkey HoofHearted
    Aug 2004
    Swampyland, UK
    122
    Post Thanks / Like
    The ends of the fabric-braided vacuum hoses often cause problems on these when they crack.
    Check each end for degridation (carefully pull them off, and inspect the inner bore), and if necessary, cut half an inch from the end of any suspect hoses, re-atach, and see how you get on.
    Sean - Independent Motor Vehicle Technician (ret’d)
    2007 Audi B7 (8EC) RS4 quattro saloon 4.2 FSI V8 32v (BNS) (with ceramic brakes ) - V-max = 9.8mpg @ 172 mph - WOW
    2006/7 VW A5 (1K) Golf Mk5 GTI 5dr 2.0T FSI (BWA) DSG, fully loaded, colour coded,
    1998/9 Honda CBR600FX - the blueberry trifle
    2003 Audi B6 (8E) S4 quattro saloon 4.2 V8 40v (BBK) 6sp man, fully loaded (gone, but not forgotten)
    vw754's Avatar
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    PD 115 bhp,very sluggish car,timing checked using proper lock tools,been on vag-com and snap on fault diagnostic equipment,also been to dales diesel injection specialist..no faults except one( n75 boost valve positive deviation) replaced the n75,still comes up with same fault,but only after driven for a few hours.
    Car does not throw out any smoke maf sensor and all pipes have been checked for splits diagnostic shows all to be ok,revs ok on idle,sounds a bit rough/slightly noiser than normal,and heavy on fuel consumption
    Any ideas? its a 2001 gt tdi 115 bhp pd engine done 120k.
    Can anyone also tell me what that round plastic ball like thing on the front of the engine is and what it does? Car has driven me nuts!
