JMB RetrofitsVolks Autos
    Apr 2014
    Gearbox Conversion
    So far the BKC transplant into our 2008 Leon 1.9 TDi is holding up well 400 miles in. I have since been thinking about the possibility of fitting a higher ratio gearbox for better economy/more relaxed cruising in place of the standard 5 speed. I read somewhere about fitting a 6 speed gearbox which also requires different driveshafts, selector, possibly clutch and flywheel? The only thing which can be left are the selector cables apparently.
    Having driven a 2008 Audi A3E 1.9 TDi 5 speed not too long ago, I noticed most of the ratios were quite a bit higher than our Seats, I think 5th gear gave about 70mph at 2000 rpm. Ours is doing around 2350rpm at 70mph. So now I'm thinking about how to find an Audi E, Golf Bluemotion or Leon Ecomotive 5 speed gearbox which should be easier and cheaper to fit than a 6 speed.
    My first question is, has anyone done this before? And my second question is doe anyone know the gearbox codes for these type of ratios? I'd hate to buy the wrong 'box.
    Looking on eBay so far hasn't uncovered any specific 'economy' 5 speed 'boxes, so the codes would be really useful.
    Any advice would be gratefully received.
    Jan 2012
    1,837
    KBL is the gearbox code from my TDIe.
    Apr 2014
    Hi Chris
    Thanks for that. I'll have a trawl through eBay for one. What year is your A3?
    Jan 2012
    1,837
    March 09 build, MY2009. BLS engine code.
  1. Manual Gearbox Conversion???
    By jbaudi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th September 2012, 22:53
  2. gearbox help needed! -poss conversion
    By lewis2009 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2009, 21:51
  3. Gearbox Repaired!
    By Joshie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2003, 08:59
  4. DSG auto gearbox... confirmed?
    By jamesa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2003, 14:21
  5. A3 4WD Conversion!!
    By Moresauce in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2003, 15:02
