Sky InsuranceAH Fabrications
    Dec 2012
    VW Golf 1.8t 99 AGU not firing on cylinder 4 and not coil pack
    Hello,
    I have an S reg mk 4 golf agu engine. Cylinder 4 is not firing. I have swapped coil pack and checked the other coil leads and it is a problem with cylinder 4. I am getting no spark. I have read about issues with the ICM/ ignition amp module however i have not found anything relating to cylinder 4. normally it is 1 or 3????? I am sure the problem is from the connector and not the coil pack or spark plug. I do not want to pay out anymore money as already paid out for coil pack that wasnt needed.
    many thanks
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    icm, and its more common to be 2 or 4 failing
  1. Helpppp agu not firing on 4th cylinder :(
    By smokiedee in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2012, 15:43
  2. Cylinder 2 not firing
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2010, 18:59
  3. weird problem NOT FIRE-ING
    By vw754 in forum Diesel forum
    Last Post: 6th April 2007, 20:28
  4. WEIRD PROBLEM NOT FIRE-ING
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2007, 11:02
  5. Windscreen Washers not firing?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 08:50
