Chris NottVolks Autos
Results 1 to 9 of 9
    Mar 2012
    29
    Jetta V Wolfsburg Won't Start
    Hey guys, my wife's 08 Jetta 2.0T Wolfsburg Edition (Manual trans) refuses to start.
    It seems to me that the battery is weak or maybe a bad relay or fuse is stopping it from starting.
    VIDEO:
    IMG 2145 - YouTube
    Pulled the codes with VAG:
    Chassis Type: 1K0
    Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
    55096miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    0F-Digital Radio -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0020
    Revision: 5BH16
    Coding: 0403010A18070160
    Shop #: WSC 00066 000 00000
    VCID: 366824867E1D6BAC
    1 Fault Found
    000256 - Mass Air Flow Sensor (G70): Supply Voltage
    P0100 - 004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 88673 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 03:09:47
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 32.0°C
    Temperature: 33.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 11.557 V
    Readiness: 0110 0101
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0021122
    VCID: 73EEDD922DEF3E84
    1 Fault Found
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 HJ HW: 1K0 820 047 HJ
    Component: Climatic PQ35 141 1010
    Revision: 00141028 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    No fault code found.
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
    Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000000885454
    Coding: 14058E234004150007140000001400000008730B5C00010000 0000000000
    VCID: 6FE6D1E241C71A64
    Part No: 1K1 955 119 E
    Component: Wischer 040308 021 0501
    Coding: 00038805
    Shop #: WSC 00066
    10 Faults Found
    01493 - Bulb for Blinkers; Front Left (M5)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 85824 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.55 V
    OFF
    ON
    OFF
    OFF
    OFF
    01501 - Bulb for Blinkers; Rear Left (M6)
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 88673 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 11.95 V
    ON
    ON
    OFF
    OFF
    OFF
    01505 - Bulb for Blinkers; Rear Right (M8)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 88673 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.00 V
    ON
    ON
    OFF
    OFF
    OFF
    00987 - Lamp for Brake Light; Left (M9)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 88673 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 11.90 V
    ON
    ON
    OFF
    OFF
    OFF
    00988 - Lamp for Brake Light; Right (M10)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 88673 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 11.45 V
    OFF
    OFF
    OFF
    OFF
    OFF
    01504 - Bulb for License-Plate Light (X)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 88673 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 9.20 V
    ON
    ON
    OFF
    OFF
    OFF
    01519 - Bulb for Back-Up Lights; Right (M17)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 88673 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 9.20 V
    ON
    ON
    OFF
    OFF
    OFF
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 218
    Mileage: 88673 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 7.55 V
    OFF
    ON
    OFF
    OFF
    OFF
    00154 - Windshield Wiper Motor; Passenger Side (V217)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 88673 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 9.60 V
    OFF
    ON
    OFF
    OFF
    OFF
    02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 88673 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 9.60 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
    Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
    Component: SDAR SIRIUS H07 0150
    Revision: 00000000 Serial number: AUZ4Z7H0278782
    Coding: 0000000
    VCID: 336E1D926D6F7E84
    1 Fault Found
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 88673 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 03:10:31
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
    Component: 6A AIRBAG VW8R 034 8000
    Revision: 05034000 Serial number: 003B6M04HPZ.
    Coding: 0013889
    VCID: 6CDCC6EE70D1E17C
    Part No: 1K0 959 339 F
    Component: BF-Gewichtsens. 007 0005
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BF HW: 1K0 953 549 BF
    Component: J0527 051 0100
    Coding: 0000021
    VCID: 77F6E982399752A4
    5 Faults Found
    00576 - Terminal 15
    00883 - Ignition Switch (D) Terminal S
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 954 P HW: 1K0 920 954 P
    Component: KOMBIINSTRUMENT 3HL 1222
    Coding: 0023203
    Shop #: WSC 05074 444 64667
    VCID: 39722FBA4F0384D4
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533 Gateway H07 0052
    Revision: H07 01 Serial number: 220108F1001278
    Coding: E9807F070003021002
    VCID: 3064129E9C79459C
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO 3HL 1222
    Shop #: WSC 05811 444 102991
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1133
    Revision: 32008001 Serial number: 00000594088110
    Coding: 0001205
    VCID: 3B7E35B2453FB6C4
    1 Fault Found
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 88673 km
    Time Indication: 0
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.070 H08 1901
    Shop #: WSC 02069 000 90108
    VCID: 356A238A631B60B4
    3 Faults Found
    00778 - Steering Angle Sensor (G85)
    000 - -
    Freeze Frame:
    00668 - Supply Voltage Terminal 30
    Freeze Frame:
    Mileage: 0 km
    Temperature: -70.0°C
    Voltage: 0.00 V
    Voltage: 0.00 V
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Freeze Frame:
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
    Component: KSG PQ35 RDK 052 0221
    Revision: 00052000 Serial number: 00000000000000
    Coding: 13900F880186281B0904058FB0880F0488DCA0
    VCID: 840C0E4EF841893C
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1133
    Revision: 32008001 Serial number: 00000082888221
    Coding: 0001204
    VCID: 3C7C36AE4031B1FC
    1 Fault Found
    00110 - Right Mirror Turn Signal Lamp (L132)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 11
    Reset counter: 178
    Mileage: 88673 km
    Time Indication: 0
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
    Component: Radio DE2 016 0020
    Revision: 00016000 Serial number: VWZ4Z7H2187777
    Coding: 0010400
    VCID: 2952FFFABFA33454
    3 Faults Found
    014 - Defective
    01305 - Databus for Infotainment
    014 - Defective - Intermittent
    02218 - Satellite Radio (R146)
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
    Component: J388 TUER-SG HL 1120
    Revision: 12006001 Serial number: 00000002782946
    Coding: 0001168
    VCID: 3E783CA6562DA3EC
    Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
    Component: RDK 0450
    Coding: 0100101
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
    Component: J389 TUER-SG HR 1120
    Revision: 12006001 Serial number: 00000002793198
    Coding: 0001168
    VCID: 3F8641A25127AAE4
    Chugger
    North Devon
    2,716
    You said it yourself, looks like it needs a new battery, a simple test will tell
    57 A3 2.0 TDI Sportback (140)
    Jun 2011
    Great Melton Norfolk
    1,356
    cant you test/check battery with vcds in engine/elecrical modules?
    Chugger
    North Devon
    2,716
    Yes you can, not too familiar with vcds, but you should be able to scroll through the engine module readings to give you voltage, or you can just test the battery voltage with a multimeter (far easier). Should be just over 12v when off, might drop to about 9v when cranking, and between 13.8-14.4v when running iirc
    Mar 2012
    29
    well, I didn't get a chance to test my battery with vcds yet, but it reads 12.80volts right now.
    So I am thinking that the battery is fine.
    Could the ignition switch be the culprit since vcds gave me the following errors?
    Is there a fuse or a relay for ignition?
    5 Faults Found
    00576 - Terminal 15
    Mar 2012
    29
    scanned again and got the same codes. does anyone know/have the part # for the ignition switch?
    Mar 2012
    29
    Is my HPFP bad?
    Mar 2012
    29
    Replaced the ignition switch with OEM part # 1K905865A didn't fix the problem. The car still doesn't start.
    The plug that connects to the ignition switch if faulty and shorts out. If you are getting the codes that I got for ignition don't replace your switch.
    I am thinking that the HPFP is faulty. Does anybody know how to test it?
    Mar 2012
    29
    any thoughts why the fuel pressure regulator is negative?
  1. 95N A4 2.6 V6 - Won't Start
    By outmydepth in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2004, 17:37
  2. Uh-Oh...it won't start....
    By Manics in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2004, 17:40
  3. Car won't start in morning!!
    By JayA4Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2003, 23:25
  4. Car won't start in the mornings!
    By JayA4Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2003, 08:45
  5. Won't start!!
    By ray_nsm in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2003, 00:25
