Sky InsuranceVolks Autos
    Sneekyparrot's Avatar
    Jun 2012
    Birmingham
    42
    Question Tick over starting issues . Bam motor mgzs180
    Hi guys,
    Hope my first post iis in the right place!
    Ok I run a 300hp bam / hybrid motor in a mgzs180 shell.
    The car I am told used to run perfect at tickover etc but when I got it the tickover is bad . Once started u have to keep it revving to stop it stalling , after 30 seconds it will sort of tickover but very rough and almost hesitating almost stall then pickup again. I the car stalls then u have to pump throttle like mad to get it running. With a tiny bit of throttle all is fine and once on the move the motor is great.
    So any ideas where to start sourcing the problem would be appreciated
    paul
    Jun 2011
    Great Melton Norfolk
    1,356
    Have you scanned it with vcds?
    Jun 2012
    Birmingham
    42
    Quote Originally Posted by gen.heinz guderian View Post
    Ok without sounding dumb bearing in mind I am new to the 20vt I take it vcds is some kinda of diag software / device?
    Thx
    paul
    Jun 2011
    1,356
    yes it is look in the vcds section on here, see if anyone in your area has got it . Ask them if they could scan car for you.
    Jun 2012
    Birmingham
    42
    Thx I will give it a look.
    Paul
  1. Tick over and starting
    By audia3vwgti in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2009, 15:31
  2. slight ticking on tick-over
    By slimbloke in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2004, 13:11
  3. A6 no tick over
    By imported_BeauA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd August 2004, 13:25
  4. Replies: 12
    Last Post: 19th May 2004, 11:06
  5. tick over
    By dwarfslapper in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2004, 18:01
