Sky InsuranceChris Nott
Results 1 to 17 of 17
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    Failed MOT on emissions
    Hi there guys......my friends car failed its MOT on emissions and he has a retest next week. The mechanic who did the test reckoned if i took the fuel head (i think) off and clean it. It would help. Also to put something in the engine to help clean it out (he didn't suggest what).
    The car has been kept in storage for 6 months and has hardly been driven since. Would giving it a good run help at all?
    Any other suggestions?
    Thankyou
    Here are the readings:
    Erf
    Oct 2006
    Kingston
    233
    Did you check out the thread before yours? Just wondering
    Might be worth a check for 70 quid...
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,503
    oil change and a clean of the pcv system wouldn't go a miss and then some fresh fuel, maybe with a cleaner or octane booster, then thrash the crap out of it before re taking it
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,366
    Quote Originally Posted by MrTackalakalaka View Post
    Thankyou
    About 5 years ago I had a car fail, the mechanic told me to go and put a forte fuel treatment in with a full tank of shell optimax and go drive that tank of fuel out, took it back And it passed!
    Worth a try....... Forte engine treatment yellow one and 50 litres of optimax. Free retest within 7 days.
    Hope this helps
    beachbuggy's Avatar
    Surrey
    1,741
    Mine did a similar thing last week. So co2 is way high and lambda is very low ie rich , which will throw co2 out. I'd suggest fault lambda sensor and best way to check is to vagcom it and log block 31 this will tell you what the ecu is seeing. Also co2 could be high as the rich fuel has clogged the cat assuming it had one. It may need a stinking good drive to burn it all off 3rd gear high rpm for 10-15mins at least to get cat nice and hot. I don't a bottle of magic liquid will help in this case as your readings are way off! I'd be inclined to swap the lambda if you have one to see how it goes.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Quote Originally Posted by beachbuggy View Post
    The print out suggests its a Mk3 Golf (2ltr GTi as its 1984cc).... non of your block 31 shizzle here... hence why I moved the thread into this part of the forum
    <tuffty/>
    Viking's Avatar
    Mar 2010
    215
    Thankyou
    According to the MOT test manual (online here) the CO test limit for a vehicle first used before 1986 is 4.5% at natural idle. If your car is a 1984 model then it appears as though he's applied the test limits for the wrong year of vehicle as the natural idle test result he's recorded is clearly below the limit, yet marked as a fail.
    Or am I missing something?
    Apr 2004
    12,503
    N reg is around 93-94 mate
    Viking's Avatar
    Mar 2010
    215
    Indeed it is. I was looking at the engine capacity (1984) and thinking it was the year....
    Carry on.
    Jan 2012
    Truro, Cornwall
    426
    Thanks very much for the info!! a big help!
    Sorry tuffty. Habit from posting on s3 thread.
    Will Vpower do? with injector cleaner etc or is there a better fuel to use?
    carl-1968's Avatar
    May 2012
    Nottingham
    455
    V-power is the best on the market and Forte is damm good stuff, fill up and go for a drive as already said 3rd with 3-4k rpm for about 15-20 mins and then back to the test station unless you have a faulty sensor it should go through, good luck
    Jun 2011
    Great Melton Norfolk
    1,344
    my mk4 failed on emissions ,the Garage just put injector cleaner through it and retested it,it passed. They did tell my wife it needed a good service,but i had done it 3 weeks previously with VW parts.
    Jan 2012
    Truro, Cornwall
    426
    Thanks for that!! Going to sort it out tonight! Fingers crossed it works!
    Thanks again to everyone for their info/advice
    Jan 2012
    Truro, Cornwall
    426
    Had the re-test today.......went through absolutely fine!! Thankyou to everyone for your advice........
    Ended up doing:
    Oil Change
    Oil Filter
    Filled Car up with V-power and put Wynns low emissions in
    Cleaned Air filter
    Took it for a good drive
    Steve B5 Biker's Avatar
    Jan 2012
    SOUTH YORKSHIRE
    128
    N reg is 1995/6 cos mi bike an N REG
    Quote Originally Posted by Byzan Pics View Post
    Aug 2010
    1,540
    93/94 would be a late k/early l plate. indeed 95/96 would be late n plate/early p.
    Apr 2004
    12,503
    In my defence i did say around,lol
  1. car failed mot on emissions =(....
    By E4 FENN in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2010, 20:11
  2. S3 Failed MOT on emissions
    By s3jack in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2010, 14:45
  3. Failed MOT on an AMD remaped S3 due to emissions
    By S3_Shaun_84 in forum Tuning
    Last Post: 17th May 2006, 23:43
  4. Failed MOT
    By mattpanton in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd March 2006, 17:01
  5. failed MOT
    By rickparmar in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2004, 21:44
