Chris NottEM Tuning
    Feb 2012
    Golf ED30 Low Pressure Fuel regulation
    Sorry to join this site because i dont have an Audi however i hope someone has some answers to my problems i just recently occurred. I started having problems with my car when i fitted the RS4 valve to help my flatspot i was getting (stage2)... The following day the engine cut out about 3500rpm, felt like fuel cut / or someone hitting the brakes hard for me. The car goes into limp mode then.
    I then returned the OEM valve back in and the problem still persists.
    2 Faults Found:
    012555 - Low Pressure Fuel regulation
    P310B - 002 - Fuel Pressure Outside Specification - Intermittent
    I changed the low pressure sensor today and still happens, so i have logged the low / high fuel sensors to see whats going on. A guy on the gti site says it could be my tank pump has become faulty. (Could i have caused this when i was cranking the engine over till i got it started when i refitted the valve) ??
    Any help would be great.. The cam follower is perfect, and the HPFP is clicking away (i did the test via vagcom)
    Thank you for your time.
    [img width=786 height=441]http://i1178.photobucket.com/albums/x371/ktlstar/fuel2-1.jpg[/img]
    [img width=786 height=441]http://i1178.photobucket.com/albums/x371/ktlstar/fuel3pg-1.jpg[/img]
    [img width=786 height=441]http://i1178.photobucket.com/albums/x371/ktlstar/fuel4pg.jpg[/img]
    Aug 2010
    1,540
    tfsi engine? not come across this before. is the sensor you changed the "g410" pressure sensor. ive heard of this going faulty. if its still happens it could be a wiring fault or maybe the fuel pressure is actually "outside specs".
    above all tho, have fun!
  1. 000665 - Boost Pressure Regulation: Control Range Not Reached
    By Synchromesh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd November 2011, 20:02
  2. 16683 Boost Pressure REgulation Control range not reached
    By Kev_M5KPL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2010, 20:22
  3. WILL A GOLF ED30 ENGINE AND ECU GO IN AN A3 QUATTRO?
    By jon-tfsi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th June 2010, 20:07
  4. G410 low fuel pressure sensor issue on S3
    By DemianM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2009, 00:16
  5. Boost pressure regulation!
    By s_line_junkie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th May 2009, 19:04
