UnicornAMD Technik
    tdi-man's Avatar
    Jul 2009
    990
    Post Thanks / Like
    vw sharan x reg 1.9 tdi
    m8s got a passenger side indicator probelm.
    when indicating left relay just clicks realy fast . wheres the relay ? any ideas on relay number
    also the green light on the dash does not come on.
    have changed hazard relay switch and all bulbs .
    any ideas ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium door inlays / panal filter / Egr delete / custom map with hot start fix + warm idle fix / Hybrid Turbo / Helix clutch / 12mm Rear spacers / 10mm Front spacers
    213 bhp - 294 ft lb - 399 nm
    Wifes car - Mk4 Golf GT TDI 150 - 18s - remapped
    FOR SALE
    TANDEM PUMP
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,291
    Post Thanks / Like
    Blog Entries
    the indicator relay flashes quick when the bulb is out.
    if you changed all bulbs. have you checked to make sure no other light is on at the same time of indiator?
    Like a brake like or fog light flashing, which suggests a bad connection or earth issue?
    tdi-man's Avatar
    Jul 2009
    990
    Post Thanks / Like
    ok thanks will get m8 to check bulbs again and lights
    you dont get a bulb out warning on dash
    also the indicators dont flash at tall
    FOR SALE
    TANDEM PUMP
  1. Vw sharan heating unit
    By shariain in forum Volkswagen and other VAG
    Last Post: 21st January 2012, 15:51
  2. Replies: 0
    Last Post: 16th October 2011, 13:00
  3. Replies: 0
    Last Post: 13th October 2011, 11:51
  4. sharan
    By truebrummie in forum Volkswagen and other VAG
    Last Post: 21st May 2008, 18:46
