EM TuningChris Nott
    Nov 2004
    Fed up of my Polo! (or nearly)
    Hi all - new here!
    I had (and still have but garaged) a 1967 VW Beetle. Based on the experience I had with the Beetle when time came to buy a new car I bought another VW - Polo (1995 model) 1.0 litre.
    Apart from the fact that is it a low performer (but that is my fault as I bought a 1.0 ltr - though the 1.0ltr Peoguet 106 is much faster) it is currently performing much less.
    This is the 4th time this happened (roughly once a year)...I take it to my VW dealers and says he cleaned the throttle valve. The symptoms are... low performance and sometimes engines stalls when idling. After cleaning it improves quite a lot.
    Now, after a year, it is doing it again. Have you guys suffered from this or know what should be cleaned? I really like to do it myself this time to avoid the hassle. (I used to do things on my beetle)
    Mario
    Andy101's Avatar
    Nov 2004
    North Yorks
    166
    Re: Fed up of my Polo! (or nearly)
    I had a similar problem with a Mk 1 Golf. After alot of trial and error (including a new carb) it was eventually traced to a filter on the fuel pick up in the petrol tank. Not sure if the Polo has one but worth a look
    [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    Nov 2004
    I managed to locate the throttle valve. According to the local agent that was the cause the last 3 times. It's on the rear of the throttle body, were the gas cable is attached. there is supposed to be a valve...I'll try to clean it this saturday.
    imported_YOGi
    I used to get this on my old polo. It would cut out randomly, happened twice while i was on a national road. Had to franticly re-start it - remember as it stalled i had no breaks or power steering at 40ish mph.
    I found that a good clean of the throttle body, new high power battery (if you think it needs it) & also make sure the old girl is serviced well. E.g. spark plugs, oil & air filter, fuel filter depending on mileage are changed at least once a year.
    It worked with my old polo, a bit of TLC will go a long way. Good luck YOGi
