JMB RetrofitsBadger5
Results 1 to 7 of 7
    Oct 2003
    eindhoven
    rs4 engine in my golf mk 3(vr6)
    does anyone know if this is done before?
    Oct 2003
    berkshire
    97
    Re: rs4 engine in my golf mk 3(vr6)
    what engine does the rs4 have?
    can't see the point in gettin rid of a vr6 myself - proably better to tune it up instead.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    the engine would be worth more than the car, and traction would be a real problem so isnt really worth it...
    RS4 = 2.7 v6 bi-turbo 380bhp
    Rich
    Oct 2003
    berkshire
    97
    exactly what i was tryin to get at!!!
    get this shopping list for your vr, it'll still probably be cheaper, and you won't be dissappoited....
    corrado throttle body,
    schrik vsr inlet manifold,
    torque biasing diff,
    gemini six speed conversion with custom ratios (as opposed to one with normal ratio's but a longer 6th gear).
    obviously you can do a lot to the suspension and brakes to get the most out of it, but you'll be having scooby's with the above...but it will cost about 4k!!
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    new rs4 engine is around 40k parts only obiously you can get them cheaper if you can find them at breakers
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    are u saying a new engine is 40grand???????
    think even from the "stealers" that is a bit dear!!!!!
    nervus's Avatar
    Apr 2004
    1,159
    You can get a 2 year old RS4 for 35-40K for the entire car. the engine is likely to cost around 18K from the dealers.
    A VR6 with a corrado throttle body and shrick inlet manifold will not have scoobys - at all! At best it will stay with a classic uk spec (212BHP) Impreza turbo.
    Your best of going down the 1.8T route with modified turbo and map. K04 (S3 TT) turbo and remap = 260 - 280 BHP
    IHI roller bearing turbo uprated injectors etc and remap = 300+ BHP but i rekon your talking at least 5k which is becoming more expensive than most mkIII golfs so your better off buying a MKIV turbo 7K for a good un and chipping it to 200 - 220 BHP for 400 - jabbasport
