AWEsome GTIAdrian S Flux
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    Hot starting issue
    golf mk5 tdi 105 bhp..........starts ok when cold but once hot it take a good few (around say....5 seconds) to start,ive heard its the starter motor if this is the case,can it be repaired? and how can i tell if it is knackered ,i mean it still works.....what do i do? car drives 100% and starts at the first turn of the key when cold,no faults via vag and coolant temp sensor is ok aswell
    lowered/half leather trim/leather armrest/led's/mood lighting//red calipers/ lifeshine paint protection/plenty of autoglym/poorboys natty's blue/ch/lh ights
    vw754's Avatar
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    BUMP!!!!
    Banned
    Aug 2010
    823
    Post Thanks / Like
    doubt it's the starter motor if it cranks over for 5 secs, will be more down to the fuel / air mixture being incorrect, hot engines need more air and less fuel to start i believe
    Oct 2011
    40
    Post Thanks / Like
    ECT faulty would be my guess.
    When the engine is hot, disconnect the wiring plug from the ECT and try starting. If it starts straight up, replace the ECT.
    vw754's Avatar
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    thanks all..............but it was the starter !!
    I did disconnect the coolant sensor........and it was checked with vcds and it was giving the right readings........when you disconnect it ,it alters the fuel/air/timing and starts straight away...........replaced starter and its ok.
