My sons 2L GTI has poor fuel economy and occasional mis fire since he bought it. Got hold of VCDS and below are the following codes that have been generated in 1 week after clearing the originals. I've checked the connections under the OS sill and appear ok. Am i right in saying this is the sensor after the Cat and not the one in the manifold? Has it failed or can you clean it?
Cheers.
Monday,30,August,2010,14:33:44:46862
VCDS Version: Beta 912.0
Data version: 20091201
Address 01: Engine Labels: 06A-906-018-AQY.lbl
Control Module Part Number: 06A 906 018 EF
Component and/or Version: 2.0l R4/2V MOTR HS V04
Software Coding: 00031
Work Shop Code: WSC 00490
9 Faults Found:
16525 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit: Malfunction
P0141 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
P0139 - 35-00 - -
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 35-00 - -
LinkBack URL
About LinkBacks
