Badger5DTUK
Results 1 to 7 of 7
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    7,416
    Post Thanks / Like
    Heavy Steering - Re-coding??
    Just had a new steering rack fitted but now the steering feels considerably heavier. Also doesn't seem to self centre so well when coming out of a turn.
    Read somewhere that it could need re-coding to get things back to normal.
    Anybody know if this is true and if so, how??
    My "SPORT" to "S-LINE+" Conversion *COMPLETED* (Part No's, Prices & Tips included)
    A3 2.0TFSI DSG Bluefin
    Quote Originally Posted by Ads View Post
    Those who can, do. Those who can't, teach.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    7,416
    Post Thanks / Like
    Scanned the car for faults and...............
    Address 16: Steering wheel
    Control Module Part Number: 8P0 953 549 F
    Component and/or Version: J0527 H34 0070
    Software Coding: 0011112
    Work Shop Code: WSC 06314
    Additional Info: XXXXXXXXXXX E0221 H03 0080
    Additional Info: Geraet 00000
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication - Intermittent
    Address 44: Steering Assist
    Control Module Part Number: 1K0 909 144 H
    Component and/or Version: EPS_ZFLS Kl. 69 2901
    Software Coding: 0000000
    Work Shop Code: WSC 00000
    2 Faults Found:
    03803 - Unknown Error Code
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 76024 km
    Time Indication: 0
    Date: 2010.07.01
    Time: 00:23:56
    Freeze Frame:
    Battery Volts: 12.2 V
    DD
    Temperature: 35.0°C
    Count: 3
    Steering Angle: 0.00°
    Count: 1
    SteerAng n.Init
    00750 - Warning Lamp
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 76024 km
    Time Indication: 0
    Date: 2010.07.01
    Time: 00:00:03
    Freeze Frame:
    Voltage: 12.25 V
    DD
    Temperature: 32.0°C
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Address 03: ABS Brakes
    Control Module Part Number: 1K0 907 379 AA
    Component and/or Version: ESP FRONT MK60 0102
    Software Coding: 0021122
    1 Fault Found:
    01309 - Power Steering Control Module (J500)
    008 - Implausible Signal
    Also, just for the fun of it I tried:
    Sensor for Steering Angle (G85)
    Prerequisites:
    • Start the vehicle.
    • Turn the steering wheel one turn to the right and one turn to the left.
    • Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
    • If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
    • Ensure that the steering wheel is not moved again.
    • Keep the engine running and do not switch off the ignition.
    • System voltage at least 12.0 V.
    [Select]
    [03 - Brake Electronics]
    [Coding-II - 11]
    OR
    (if Coding-II is not available)
    [Security Access - 16]
    Enter 40168, to enable the basic setting.
    [Do it!]
    [Basic Settings - 04]
    Group 060
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    After a successful basic setting, field 2 should say "OK".
    [Done, Go Back]
    To make sure the basic setting was succesful, check the sensor again.
    [Measuring Blocks - 08]
    Group 004
    [Go!]
    Check field 1, the value has to be between -1.5 and +1.5 °.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    My value was way out... something like 5.25.
    Oh, and tried getting into steering assist but it doesn't appear to be allowing me in. Keep getting "error channel 01 not available".
    Tried enabling in security settings (as advised somewhere) using code 40168. Code was accepted, but still no luck getting in.
    So basically it looks like the guys that have fitted the rack (non-audi dealer and non-audi specialist) installed the rack and have done no coding etc whatsoever.
    My car feels a right mess to drive at the moment.
    PS: the new rack that I have is an upgraded rack from audi as the older ones were problematic.
    18,288
    Post Thanks / Like
    The racks also change looms as there are 3 generations of racks mate, the new one may also require a new loom fitted, whats your old & new rack part numbers?
    Just out of curiosity, they have actually plugged the looms back into the rack yes, as this would do it lol.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    7,416
    Post Thanks / Like
    Funny you should mention looms because they had to order a new one when fitting the new rack, which delayed me getting the car back.
    Looking at the invoice it looks like the rack is part number 1K2 423 055 JX, and the harness (loom??) is part number 1K2 971 111 AJ.
    Don't know the part number of my old rack.
    As for them plugging the looms into the rack......... is there an easy to tell if they haven't??
    The steering is heavy, just not zero power steering heavy, if you get what I am. Still feels like i'm getting some assist.
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,538
    Post Thanks / Like
    Just wondering here - but is that not suggesting that there is an issue with the steering Angle sensor for the value to be that high ?
    Not looked at what is involved with changing the rack - but if the value should be between +/- 1.5 degrees and yours is reading 5.25 it would suggest that the rack home position is way out compared to the steering angle sensor.
    I do recall having some issues after I changed my steering ecu for cruise - where I had to ignition off between the proceedures.
    Paul
    2005 Black A3 (8P1) S-Line 2.0TDi DSG (Ex-MarriedBlonde). Eibach Pro Springs, Koni FSD shocks and a few bling bits inside. HEX-USB+CAN Vag-Com. Gone but not forgotten - Revo 99 GTi Turbo, too much to list mod wise. - 92 Golf Gti Mark 2 16V.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    7,416
    Post Thanks / Like
    Think I'm going to take the car to an Audi specialist to have a look. I've tried all of the calibrations and nothing seems to work.
    Since having the tracking done the steering angle is slightly less.... 4 point something I think.
    The tracking has also cured the heavy steering problem. It's back to it's usual lightness now, which I thought was weird as I didn't think adjusting the alignment would affect this.
    The only fault I am left with now is:
    1 Fault Found:
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    Update to a current version of VCDS and post a complete scan from the vehicle in question please.
    Sebastian @ Ross-Tech.com
