Step 2. From the module selection page, select [03 – ABS Brakes]
Step 3. Go to [Login – 11]
Step 4. Enter your code and select [Do It!]
Step 5. If you get the login code incorrect, you will get "Connection lost due to dropped session" error
and you will have to turn the ignition off, take the key out, and start again.
24. Once you have logged in correctly, you need to re-code the module. Formulate your coding from
Appendix B /use your previously recorded value. Mine was 04595 for the S4.
Step 1. Select [Coding – 07]
Step 2. Enter your code in “Software Coding”
Step 3. Select [Do It!]
25. When you have done that, DO NOT CLOSE THE CONTROLLER. If you do, you'll have to log in and re-code
again.
Cruise Control for Audi A4/S4 (B6 or B7)
26. Now complete the steering angle sensor recalibration. (Remember, don't close the controller before you
do this, it must be done in the same session).
Step 1. Select [Fault Codes - 02]
Step 2. Select [Done, Go Back]
Step 3. Turn steering wheel at least 30 ° left and back straight ahead.
Step 4. Select [Meas. Blocks - 08]
Step 5. Enter Group 005, [Go!]
Field 1 (Steering Angle Sensor -G85-)
Specification: 0.0 °
Tolerance (when straight): ±5.0 ° (Note - When the steering wheel is straight the value shown
should be -5 - +5 degrees, set it in between these values and leave it there for the rest of the
procedure)
Step 6. Select [Done, Go Back]
27. Next you need to code the brakes module for cruise:
Step 1. Select [Login - 11]
Step 2. Enter 40168
Step 4. Select [Basic Settings - 04]
Step 5. Enter Group 001, [Go!]
Step 6. If successful the blocks should read something like Steering Angle Adjust OK
Step 7. [Done, Go Back]
Step 8. Select [Fault Codes - 02], all fault codes should have disappeared.
Step 9. Select [Done, Go Back]
Step 10. Select [Close Controller, Go Back - 06]
