Revo TechnikAdrian S Flux
    Dec 2008
    31
    Post Thanks / Like
    Unable to log into Engine Control Module to activate Cruise Control
    Hi all,
    I installed cruise on my A3 last year with no probs. I recently installed the hardware for a colleague, and upon trying to activate the cruise by loggin into the module with '11463' got the following error:
    VCDS Login Invalid
    'Login Code not Accepted by Controller'
    I have tried searching the forums for answers but no luck. I got some google results about some modules not supporting login to activate , and that people configured cruise using the long coding - but I cant find how you would do this.
    Here are some VCDS extracts:
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 CC HW: 028 101 183 2
    Component: R4 1,9L EDC 0000SG 7999
    Revision: 12345678 Serial number: AUX7Z0F2FNU0DY
    Coding: 0000071
    Shop #: WSC 06314 000 00000
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 034 0070
    Coding: 0000022
    No fault code found
    Any help appreciated
    18,288
    Post Thanks / Like
    Which equipment did you install & are you sure his AH steering CU is cruise compatible?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Dec 2008
    31
    Post Thanks / Like
    Hi,
    I installed a genuine cruise stalk from Audi - I didnt run the extra 'cable' to the bulkhead as this car is a '56 and I didnt think they need it? (I had to run the cable on my 2004 3.2).
    I coded the SWC using VCDS and it accepted the coding for 'cruise but no o/b comp'. I can see the buttons working in measured values.
    I dont see why the engine module wont take the '11463' code, as i would assume this is unrelated to the SWC?
    I read on some A4 posts about the '11463' method not working for some SWC controllers?
    TIA
    Fossie
    2,746
    Post Thanks / Like
    The retrofit CC kit for vehicles with the AH controller includes a new steering controller and costs £220.
    The kit for vehicles with the AF controller doesn't include a new unit and costs £62.
    Therefore I assume that AH does not support CC !
